Her er høstens nyheter fra oss i pure sound.
The pure sound A30 amplifier was developed to meet the demand for an affordable Class A amplifier that would be compatible with all types of loudspeakers. The A30 is a line level integrated design that allows for the selection of up to 3 different source components and control of the volume by a high quality ALPS Blue Velvet potentiometer. Class A operation was chosen because it gives lower distortion and a more relaxing, natural sound.
Features
Class A operation
3 Line level inputs
30 Watts per Channel Output
4 and 8 ohm output taps
Twin valve rectifiers
Choke smoothing
ALPS potentiometer
SCR coupling capacitors
Carbon film resistors (for better sound quality)
ElectroHarmonix (Russia) 6550 output tubes
Very substantial construction including cast metal transformer shrouds.
The pure sound A8000 CD Player was developed as a high quality source to be used with the pure sound range of amplifiers. It can also be used in a wide range of other systems with great success.
The A8000 is built around the SONY 213Q high precision mechanism, renowned for both its stability and reliability. A proprietary 24 Bit 192KHz D/A converter handles the data stream, which, once converted, is filtered using OPA2604 Op amps. The powerful output stage comprises a pair of 6N3 double triodes. Signal coupling here is via MIT capacitors while the output stage power supply utilises the German MCap capacitors.
Flere produkter og mer informasjon ang nevte produkter finner du på www.puresound.no og www.puresound.info
mvh pure sound
Features
Class A operation
3 Line level inputs
Choke smoothing
ALPS potentiometer
mvh pure sound
94.1 KB Visninger: 750
219.6 KB Visninger: 294
