Resultater 1 til 1 av 1
Nyhet: Yter kabler.
Abonnér på denne artikkelen
  1. Yter kabler.
    0 Kommentarer Av vassagohifi - 30.11.2007 11:07
    Vi søger forhandler i norge af disee top kabler.
    During my last challenging project, the "Stradivari Homage", I felt the need to use an internal wiring conductor which was not another product derived from the telecommunication industry with solutions based in radio frequency theories, but a materials solution with properties designed to handle bandwidth frequencies and power levels.
    So emerged a new conductor based in conceptual and structural terms, on the following premise: the transfer of the audio signal from amplifier to speaker, and in particular those at the micro signal level, depends more on the physical structure of the metal than on the absolute value of conductivity in the wire.
    Internal wiring in Stradivari Homage, Amati Anniversario and Guarneri Memento.
    Laboratorium is dedicated to the entire manufacturing process for this new project. First, there is the melting of Silver and Palladium to create our alloy. We then cold extrude our special alloy in a water bath to form an electrostatic balanced, Gaussian shaped conductor. The component connectors are then realized using our same special alloy.
    Finally, conductor and connector are cold fused with a mechanical weld where solder is neither desired nor required. With the finished speaker cable product, the music signal passes through YTER and only YTER. The result is a Reference speaker cable fit not only for Stradivari Homage, but all other fine loudspeakers of the world.
    www.vassagohifi.com
    Vedlagte bilder
  2. Antall kommentarer 0
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
