Yter kabler.
Vi søger forhandler i norge af disee top kabler.
During my last challenging project, the "Stradivari Homage", I felt the need to use an internal wiring conductor which was not another product derived from the telecommunication industry with solutions based in radio frequency theories, but a materials solution with properties designed to handle bandwidth frequencies and power levels.
So emerged a new conductor based in conceptual and structural terms, on the following premise: the transfer of the audio signal from amplifier to speaker, and in particular those at the micro signal level, depends more on the physical structure of the metal than on the absolute value of conductivity in the wire.
Internal wiring in Stradivari Homage, Amati Anniversario and Guarneri Memento.
Laboratorium is dedicated to the entire manufacturing process for this new project. First, there is the melting of Silver and Palladium to create our alloy. We then cold extrude our special alloy in a water bath to form an electrostatic balanced, Gaussian shaped conductor. The component connectors are then realized using our same special alloy.
Finally, conductor and connector are cold fused with a mechanical weld where solder is neither desired nor required. With the finished speaker cable product, the music signal passes through YTER and only YTER. The result is a Reference speaker cable fit not only for Stradivari Homage, but all other fine loudspeakers of the world.
www.vassagohifi.com
vassagohifi
vassagohifi sine annonser
Mød os på Sweetspot i denne weekend
http://www.sweetspotevents.se Mød os på Sweetspot i denne weekend, vi spiller på følgende. Rip bertramaudio Vi vil også være der med. audia flight strumento no.4 og No1 Fucus Audio...
Audia Flight
Audia Flight
Så har vi fået den første store sending hjem af Audia Flight... Vi har noget af det med på GÖTEBORG LJUD & BILD 2014 Hvor du kan finde brtrading.dk og vassagohifi.dk på Hotel Elite Park Avenue...
Gøteborg Ljud@Blid 2014
Du kan finde brtrading.dk og vassagohifi.dk på Hotel Elite Park Avenue. Hvor vi udstiller det sidste nye fra Audia Flight Strumento samt Lumin The Audiophile Network Music Player. Hotel Elite...
Audia Flight
Audia Flight
Italienske Audia Flight er tilbage hos VassagoHIFI og Bak Rasmussen Trading for Danmark Sverige Norge Finland og med en serie af nye modeller som høster topanmeldelser overalt i fagpressen som...
Yter kabler
Yter kabler
Vassagohifi har igen overtaget salget af Yter kabler i Danmark og Norge. Vi har alle deres kabler hjemme til udlån kontakt. vassagohifi rail@pc.dk +45 60199168. During my last challenging...
Aurender X100 digital musikafspiller
Aurender X100 digital musikafspiller Så er de klar i butikken. Der er to modeller, X100S på 1TB, X100XL på 2x3TB, begge to modeller er klar til demo og demo udlån,, men en masse musik på...
