Først ut i Reference serien til Accustic Arts er Tube Dac II
Prisen er 59 000 kr.
TUBE-DAC II highlights
Audiophile high precision Digital/Analog-Converter with a so called „Tube-Hybrid“ concept
Special and unique 2 x 32 Bit technology with simultaneous digital signal processing,
separately for left and right channel
Extremely elaborate digital signal processing supported by an unique 32 bit Microcomputer
The 32 bit Microcomputer contains e.g.:
- High precision crystal oscillator
- 32 bit digital filter (including „de-emphasis“ technology)
- 26 parallel working multiplier processors (32 bit)
Advantages of this „Tube-Hybrid“ technology:
- very high impedance
- very high bandwidth
- very low distortion factors and a „good-natured“ distortion spectrum
- „analog“ and very precise sound performance
Easy change of tubes without any adjustments just „plug and play“
Professional Class A output stage using technology derived from studio engineering
All used components are of outstanding quality
(e.g. 10 pcs Burr Brown® OPA 627) and additionally selected
2 premium quality rotary switches („Made in Germany“) with gold-plated silver contacts
for the input selection
2 magnetically shielded, encapsulated toroidal core transformers („Made in Germany“)
of premium quality for high output reserves
Very high power supply capacity (approx. 84,000 µF totally)
Front panel and cover are made of massive and thick aluminium
The ACCUSTIC ARTS® TUBE-DAC II is „Handmade in Germany““
Nordic Sound Design
www.base-technology.no
