VTL MB 185 og MB 450 Signature har kommet i ny utgave, og har fått navnet Series 2 i tillegg.
Monoblokkene er en ny konstruksjon men beholder sine klassiske navn.
I de nye konstruksjonene er mye hentet fra toppmodellen SIEGFRIED i Reference series til VTL.
Fra pressemelding kommet fra VTL:
MB-450 Series II Signature Monoblocks
Music connoisseurs have long admired the MB-450 for outstanding performance at a fair value. Now, VTL has significantly revised these venerable monoblocks, using many of the technological innovations derived from the flagship Siegfried Reference Amplifier. The extensive updates to each model include a revised power supply, SmartTube technology with automatic bias adjustment and fault sensing, and improved electronic components. The result is a significant advance in sonic performance, with much improved bass punch and dynamics. A sleek new chassis impressively incorporates a smoked glass window, giving users a glimpse of the glowing tubes within. These monoblocks are ideally suited for those seeking a thoroughly modern high-power amplifier that competes in sonics, looks and usability with the very best.
Feature List:
1. VTL proprietary Signature output transformer
2. Software microprocessor controlled
Tetrode/Triode Switchable
Auto Bias, Fault Sensing
Current in-rush limiting
Standby Mute function
3. 450 watts per channel in tetrode; 200 watts per channel in triode
4. 8 6550C or KT-88 tubes per monoblock
5. Regulated screen supply and separate fusing
6. Discrete regulated input and driver supply
7. Redesigned fully balanced input and driver stages
8. INFINI caps
9. Extruded aluminum front panel with luxurious, modern look black and silver options available
10. Front panel window of thick smoked glass reveals the glow of multiple output tubes
11. Rack mountable
12. Rigid construction and improved heat ventilation
Veil. pris MB 450 Signature Series 2 : 135000,- NOK
Den samme konstruksjonen gjelder også for MB 185 Signature Series 2. MB 185 er 300w monoblokker med 6 6550C eller KT88 rør pr monoblokk.
Veil. pris MB 185 Signature Series 2 : 95000,- NOK
For mer info : http://www.hifistasjonen.no
Kontaktinfo : Telefon butikk : 0047 62416121 eller Telefon mobil : 0047 40850814
Mail adresse : mail@hifistasjonen.no
Feature List:
8. INFINI caps
11. Rack mountable
33.8 KB Visninger: 6.684
