MonoPulse
  • Audiomix
    Her er Norges mest utbredte MonoPulse høyttaler:
    Model 42A
    Designet er spesielt. Utenfra og inn. Sidene til MonoPulse er nyttig lesing for alle som er interessert i høyttalere.
    http://www.monopulse.co.uk/
    The main purpose of the MonoPulse hi-fi loudspeaker design is impulse synchronism. It is not possible to achieve this with split or multiple mid and bass drivers. The MonoPulse design has to use expensive very high-quality combined mid/bass units closely-spaced with the HF units. Multiple drive-unit "arrays" lose the time-domain precision essential for leading-edge accuracy. See "The Quest for Realism" for a full explanation.
    With crossovers set at a high frequency, the MonoPulse design avoids "dual speakers" operating in the fundamental frequency spectrum of the human voice or musical instruments. The avoidance of a crossover in the range of the human voice is particularly important. It is the “instrument” we are most familiar with, and we are very sensitive to inaccuracies.
    Also, the HF crossover is fourth-order, giving very good overload protection of the HF unit.
    Det lille, men raskt voksene MonoPulse samfunnet kommer med bidrag etter hvert :)
    mteinum
    Øya
    Mono Pulse
    Ja se her ja! Om ikke så lenge så kommer det et par til Sørlandet også.
    Audiomix
    Mono Pulse
    Etter snart to år var det på tide med en egen tråd :)
    Mono Pulse himself, Allan Hendry, er en meget sympatisk og imøtekommene herre. Det har "alle" oss som har hatt kontakt med han erfart.
    Selv om min første kontakt var kort og merkelig, kom han raskt tilbake med informasjon og en forklaring:
    Good morning Hans,
    Thank you for your phone call. I am sorry if I seemed to end it a bit quickly - I was in fact on a petrol station forecourt.
    That is a very impressive and beautifully built amplifier you have made.
    Your friends are right. Regardless of the original quality of a speaker, the slow ageing of materials - hardening or deterioration - will change critical parameters.
    The Model 42 would be our strong recommendation. It has a combination of high sensitivity (92dB) and high impedance (6.7 ohm minimum) which we believe is unrivalled.
    Also, believe me; the accuracy of the imaging is stunning.
    Have you seen the review in issue 42 of Hi-Fi + ? If not we could e-mail or post you a scan.
    On finishes. There is a choice of Metallic Black or Gunmetal for the steel surrounds - and a choice of ten cloth colours.
    I hope you find this of use.
    Best regards, Allan Hendry
    Noen flere bilder fra den gang jeg mottok mine:
    Nå drives ikke mine Mono Pulse av min gamle Marantz, men av denne:
    Eller denne:
    yzfr17
    Moss
    Mono Pulse
    Ja, etter å ha hørt dem hos Hans endte det med bestillting av sett nr 2 og 3 til Norge
    Forsiktig avkledning
    Sjalu blikk fra utbyttern
    Skriftlig garanti (for god lyd, eller kvalitet - kanskje begge?)
    Tatt i bruk
    casper62
    Fersking
    Mono Pulse
    ;D Og hvorfor smiler jeg så bredt da....? Jo fordi jeg også er den lykkelige eier av et par 42A. Etter audiens på Kongsberg ble en kompis(yzfr17) og jeg hekta. Det tok ikke lang tid før vi bestillte. Jeg har hatt mange forskjellige høyttalere, blant annet Quad ESL, som er noe av det nærmeste jeg har kommet "ekte" lyd. Når jeg opplevde 42A, fikk jeg den samme feelingen. Jeg kommer til å få MANGE konserttimer i egen stue fremover. ;D
    mteinum
    Øya
    Mono Pulse
    Nå må ikke dere si så mye hyggelig om disse... ventetiden blir jo så lang da ::) ;D
    Pengvim
    Mono Pulse
    Disse må jeg få hørt. Noen i Romerike som har? ;D
    Mono Pulse
    Hva koster disse inn til landet ferdig levert på døra ? Tenkte på enten 42 eller 82. Utrolig fine ting da om jeg skal si det selv. Og rimelig spesielle... :)
    mteinum
    Øya
    Mono Pulse
    Det som er så morsomt og vanskelig med disse er alle valgmulighetene man har når det gjelder utseende... Veldig lekker denne kombinasjonen som ble vist i Hi-Fi Choice:
    Pilsern
    Mono Pulse
    ...synes og denne kombinasjonen er rålekker!
    Har hørt disse ved noen anledninger og liker de veldig godt.
    Tror jeg har nevnt det flere ganger på sentralen her, men de er et kjempekupp til prisen!
    http://www.monopulse.co.uk/direct.html
    JB rünnhilde
    Mono Pulse
    Designet er skikkelig ingeniør. Digg digg.
    Referanse til ESL-63 betyr at disse må jeg høre en gang. Rørfolk i Mjøsdistriktet, les tråden! Jeg er selv altfor strålende fornøyd med 86dB/W/m...
    Vidar P
    Kristiansund
    Mono Pulse
    Har ikke hørt de dessverre, men har lest tester med stor interesse. Litt blandet omtale av den mindre modellen; men såvidt jeg har lest så er dette en høyttaler som har litt "spesielle" egenskaper?
    En av de lykkelige aspekter ved å handle engelsk hifi er den overveldende imøtekommenhet og genuine entusiasme for såvel produkter som kunder disse produsentene legger for en dag. Det går på eieglede og trygghet/tilfredshet. Det er intet mindre enn ytterst imponerende; det er noe med hifikulturen der; selv UK's største firmaer (f.eks er Naim en av verdens største highend-produsenter) er akkurat like imøtekommende i direkte-kommunikasjon med kunder! Jeg tror mange av oss hifientusiaster har mye å takke folk tilhørende Peter Walkers generasjon for; de satte en standard.
    Mvh Vidar P
    Mono Pulse
    Jeg har hatt glede av å høre monopulse. Hos Audiomix var det en flott atmosfære og godlyd.... Ikke hadde jeg sett de før heller. Interessante lydspredere de der.
    JanOlav
    Sandefjord
    Mono Pulse
    Har også hørt Mono Pulse hos Audiomix, er en stund siden og lytten var ikke så lang, men jeg kan minnes at de var behagelig å lytte til.
    Så mange fine farger finner man ikke for ofte.
    mteinum
    Øya
    Mono Pulse
    Veldig heftig den blåfargen der ja. Kommer også i en litt dusere variant:
    Interiørarkitekten kan virkelig slå seg løs ja ;D
    authentic
    Mono Pulse
    Pastell er in i år... ;D
    MVH Johnny
    Audiomix
    Mono Pulse
    Siste pris på et par 42A er EUR 1130,- til norske kjøpere. Så kommer en hundrelapp eller to +mva i tillegg. Levert på døra ;)
    Jeg vet at noen har spurt om pris på 82A, men Allan har ikke svart ennå.
    R
    Rolf_Da!
    Mono Pulse
    Moro at dette merket brer om seg så raskt i Norge.
    Uten tvil mye takket være Audiomix!
    Har selv hørt dem hos Hans og likte det godt.
    (Jeg ville plassert symmetrisk, lengre ut på gulvet, lyttet i nærfelt og blablabla...Men det er bare meg. ;D)
    Er litt småbekymret for mteinum som har disse på vei og MAE som amp.
    De responderte virkelig godt på den ekstra effekten som Hans' egen amp hadde innabords.
    Kjør på med bilder i hjemmemiljø, det er moro!
    R
    Audiomix
    Mono Pulse
    R
    Det kan monteres turbo på MAE SET 1 nå. 12-14 watt gir utslag på skalaen til Richter ;)
    Synd du måtte melde forfall for 14 dager siden Morten.
    Må jeg laste opp den røde italieneren og ta en tur til?
    mteinum
    Øya
    Mono Pulse
    Jeg har en EL34PP amp på 2x30W her også, så det blir mulighet for å prøve mere effekt. Jeg får tilfredsstillende volum med MAE i kombinasjon med Snell KIII som er spesifisert til 90dB/1W så jeg er ikke så veldig redd for at MAE ikke strekker til i mitt rom, grisehøyt blir det ikke - men nok til mitt bruk.
    Jeg har lyst på en passe lettdreven høyttaler, har en frekvensrespons som går fra topp til bunn, er presis / rask, kan groove - da skal jeg være fornøyd. Skal bare ha noe som spiller Dave Grusin/Lee Ritenour og GRP jazz-fusion-pop'en på en bra måte. På papiret så virker monopulse som en god kandidat, da spesielt med fokus på fase mellom elementene og transienter. Er timinga i orden, så burde slik rytmisk komplisert musikk sitte som ei kule.
    Vidar P
    Kristiansund
    Mono Pulse
    Kan ikke dy meg for å sitere din nylige uttalelse som er til stor nedverdigelse for oss som er glad i vinyl;
    Samme prisklasse
    Uansett hvordan en snur og vender på dette er vinylen helt steinalder i forhold til det digitale medium.
    Velvel. MonoPulse er vel helt banebrytende ny teknologi da, tipper jeg.
    Uansett; er Fiat'er fortsatt laget i Italia altså?
    Mvh Vidar P
    JB rünnhilde
    Mono Pulse
    Ikke som en berg og dalbane håper jeg. ;D
    Tonal presisjon er fryktelig moderne akkurat nå. 8)
    JB rünnhilde
    Mono Pulse
    Vidar P skrev:
    Samme prisklasse
    Sett på vinger i glass eller spenn en stålbøyle rundt, og banen er brutt.  ;D
    mteinum
    Øya
    Mono Pulse
    Det går vel heller i full stopp da... Heresy var grei oppover, men i andre siden så hadde den sine begrensninger. En HT som tegner opp musikken nedover settes pris på, trenger ikke ta støvtørken - det har vi andre ting til. Helt paddeflat trenger den ikke være - liker heller en noe engasjert høyttaler, men det får da være måte på ;)
    Vidar P
    Kristiansund
    Mono Pulse
    Valentino skrev:
    Vidar P skrev:
    Samme prisklasse
    Sett på vinger i glass eller spenn en stålbøyle rundt, og banen er brudt. ;D
    Nå er jeg treg av meg altså... bare så det er sagt :) Iht gjeldende kognitive nivå, så skjønte jeg selvsagt ikke den. Til tross 1.5 gjennomlesing :)
    Mvh Vidar P
    mteinum
    Øya
    Mono Pulse
    Hei Sverre,
    Hvilken "look" var det du endte opp med?
    JB rünnhilde
    Mono Pulse
    Vidar P skrev:
    Valentino skrev:
    Vidar P skrev:
    Samme prisklasse
    Mvh Vidar P
    Disse Monopulsene har jo dette stilige industrielle bøyd flatstål-designet. Midgard Gaia har waveguides i glass, og noen mener at noen har sagt at den siste er revolusjonerende.
    Jeg trøster meg selv med at jeg forsto min egen vits.
    Vidar P
    Kristiansund
    Mono Pulse
    Aahh, say no more, say no more, eyh eyh. Men stilige er de jo da. Gleder meg til å høre et sett.
    Mvh Vidar P
    Audiomix
    Mono Pulse
    Samme prisklasse
    Mvh Vidar P
    Du må ikke plukke ut stykker fra min uttalelse om vinyl og slikt ;)
    FIAT'n er italiensk ja. Laget av pininfarina i Torino :)
    Vidar P
    Kristiansund
    Mono Pulse
    Hehe. En ufin liten hang jeg har. Beklager. Vinyl må gjerne være steinalder, på samme måte som Mozart er steinalder. Ikke noe dårligere av den grunn.
    Når får man tilsendt et sett MonoPulse for utprøving av Naim-kompatibilitet tro? :)
    Vidar
    Audiomix
    Mono Pulse
    Jeg sendte en link til Allan Hendry.............
    Hello Hans,
    That is fantastic.
    Thank you very much for doing all this.
    Best regards, Allan
    Han må nok lære seg litt norsk for å få med seg alle detaljene :)
    Setter stor pris på at det blir litt blest om høyttalerne hans.
    mteinum
    Øya
    Mono Pulse
    Så litt etter brukererfaringer på nett, og på eBay så var det en som mente følgende:
    The 82As are the big brothers of the 32A(5 star reviews) and the much aciaimed 42A.The 82As have also received excellant reviews.The best compliment I can give the 82As is that the top end has horn like qualities,most unusual for a conventional speaker,they have really good clarity.The Bass is very deep when required but not boomy, the speakers really pick out the instruments at the bottom end and can be extremly dynamic,they really grip the bass end.
    [url]http://cgi.ebay.co.uk/Monopulse-82A-floorstanding-loudspeakers
    [/url]
    Audiomix
    Mono Pulse
    Klipsch Heresy III
    Er det bare hodetelefoner mens du venter Morten?
    Apropos 82A:
    Hello Hans,
    Re the Model 82A.
    The main features of the 82A are its high power handling and low bass. But it does have lower sensitivity than the 42As 92dB. More like 89-90dB.
    That means to hear the best of what they can do, really needs a more powerful amp than the ones you are tending to use.
    If your friend does have, or get, such an amp - then I feel at least one of you should have a pair of 82s?
    We would charge E1,490 delivered - 50% and 50% as with the 42A.
    Best regards, Allan
    Ingen gal pris dette heller :)
    mteinum
    Øya
    Mono Pulse
    Audiomix skrev:
    Klipsch Heresy III
    Neida, jeg har funnet fram Snell'ene (K III), holder også på å spille inn et par med JohnBlue JB3 - så det er mye lyd i heimen :)
    Audiomix
    Mono Pulse
    R
    Enda bedre nå RoDa :)
    Har endelig tatt meg tid til å bytte til Philips EF86 + ECC83 og RDS EL34. Samt justert opp forsterkeren. Disse RDS rørene påstås av kjennere å være produsert av Telefunken (RDS var ingen produsent som kjent).
    Sammen med MonoPulse 42A spilles det vakker musikk.
    Noen ganger låter det flott fra vinylen også :)
    rolfozzy
    Mono Pulse
    Du aner ikke hvor stor pris jeg setter på at du velger disse Mono Pulsene. ;D
    mteinum
    Øya
    Mono Pulse
    Jeg har en idé ;) Det er ganske tomt i huset uten de dynamikkbombene. Jeg kommer iallefall til å være Klipschvenn for livet 8)
    Audiomix skrev:
    Hello Hans,
    That is fantastic.
    Best regards, Allan
    Kan godt tenke meg Allan er fornøyd nå som bestillingene "renner inn" ;D pretzel_logic har også vært på handletur!.
