Side 1 av 3 123 SisteSiste
Resultater 1 til 20 av 45
Tråd: Audiolab M-dac
  1. #1
    Overivrig entusiast lasse5214's Avatar
    Mar 2006
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Har noen her testet Audiolab sin nye M-Dac?
    Om så er, hvordan spiller den?
    Hva er den Norske prisen?
    Jeg har sluttet med hi-fi og hører nå på musikken.
  2. #2
    Moderator bjornh's Avatar
    Jul 2004
    Takk/Liker/Misliker
    Album
    Torget
    Musical Innovation: MI 11, MI 10.1 SE, Abrahamsen V6.0, Monitor Audio: GS20, Squeezebox Touch, Denon DCD-510AE, Blue Jean Cable, Nordost, sekundæranlegg: Yamaha: RX-V3800, BD-S1065, Focal/JM-Lab: Chorus 736S, Chorus CC700S, Chorus SW700S, Chorus 706S, prosjekt: Music Angel XD800 Mk.III rebuild
  3. #3
    Hifi Freak decibelius's Avatar
    Dec 2007
    Bislett
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Skulle ikke forundre meg om HD20 får juling av den der. (Bare spekulerer)
    Output Level @ 1KHz, RCA 2.25Vrms ±0.1, XLR 4.5Vrms ±0.1
    Frequency Response, Ref. 1kHz, 20Hz to 20KHz ±0.2dB
    THD 1KHz, 0dB, 20Hz to 20kHz BW RCA & XLR <0.0015%
    Crosstalk 1kHz, RCA >120dB, XLR >130dB
    Dynamic Range Awtd, RCA =>114.5dB, XLR =>121.5dB
    • 32Bit 84.000MHz 512 Element MultiBit Array DAC
    • Asynchronous USB supporting 24 Bits / 96kHz with Remote Control of PC / MAC Media Player via HID support
    • x2 192KHz 24Bits Coax SPDIF Digital Inputs
    • x2 96KHz Optical Digital Inputs
    • High Current, High Linearity RCA Single Ended & XLR True Balanced with fully discrete JFET CROSS* Class A Output stage’s
    • High Current, High Linearity CROSS* JFET Class A Headphone Amplifier
    • Triple cascaded Jitter attenuation stages, with triple cascaded Asynchronies Clock domain isolation – all but eliminating the First order effects of Jitter from the external input sources on the Digital to Audio Conversion process
    • Selectable DAC Mode or Digital Pre-Amplifier Mode, allowing direct connection to Power Amplifiers and Active speakers in Digital only systems
    • 2.7” High contrast OLED display
    • “Bit Perfect” Digital Data source analyzer
    • Intelligent real-time Bit Depth analysis engine – Displays the “True” Bit depth of the Digital input source
    • Digital Data Decorrelation Engine – Decorrelates the fixed “LSB’s” data pattern within the Audio data stream when less then 24Bits. Data decorrelation at the DAC substrate level reduces both Digital and Analogue Second order effects within the DAC at the silicon Die level
    • MS Windows LSB Data restoration for “Bit Perfect” reply – corrects Windows’ LSB rounding errors. Allows Bit Perfect “Plug and Play” with Windows Media Player
    • ASYNC USB Buffer level display to insure correct functionality and diagnostics of the USB HOST device in ASYNC Audio streaming mode
    • “Actual” or “Nominal” Sampling Frequency display – displays the TRUE input sampling frequency with 1Hz resolution
    • Digital level meters in dB with Peak hold
    • CD / DVD SPDIF subcode embedded Track and Time Display
    • Advanced De-Jittered Optical and Coax Digital SPDIF Output, including USB Audio
    • Selectable Optical or Coax Clock-Lock interface – allowing “Jitter Free” Clock-Locked connection with compatible CD transports etc
    • Full Remote Control + External Remote / BUS I/O loop
    • 26 Internal Regulated supply rails
    • 10 Ultra Low Noise, Low Impedance Discrete Regulators
    • 7 User Selectable Digital Filters – Fully Software upgradeable via the USB Port
    • Master Clock Jitter less then 3pS Short Term - Measured directly at DAC “XOut”
    • Organic Ultra Low ESR capacitors, High Tolerance Polypropylene film / Foil capacitors, Ultra Stable Very Low VCR 0.1% MELF SMD resistors, 4 Layer PCB
    • External upgradeable Power supply interface for a future upgrade path
    John Westlake (designer)
    Medlem av Løvblåsernes Fellesforbund (LF)
  4. #4
    Overivrig entusiast Todd's Avatar
    Jun 2009
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Noen som har fått lyttet til denne?
  5. #5
    Mar 2006
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Denne kommer til Danmark i slutten av måneden.
    Så da den er her kanskje ei uke eller to ute i Mars.
    Lasse
  6. #6
    Hifi Freak tweakMan's Avatar
    Feb 2002
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Ett veldig fonuftig og realiserbart produkt fra Audiolab dette. Denne har ett 32 bit SABRE chipsett fra ESS.
    Man tar høyde for att i prisklassen den skal konkurrere er det blitt "etter hvert" ganske vanlig att man snuser på "aftermarket" psu's som en "smerre" oppgradering eller mer.
    Man har bygd opp den interne lavvolt reguleringen med en flottilje av regulatorer og fjernet psu'en fra selve kabinettet, som jo hjelper i denne prisklassen om man gjør kretsene istand til å utnytte dette da.
    Produktet kan selges for halve prisen av tilsvarende, kanskje?
    Kunden oppgraderer psu i ettertid, men kan utnytte separeringen av støy i mellomtiden pga den eksterne psu'en.
    Jeg tror Audiolab har tenkt følgende...
    De gjør dette fordi de planlegger å kjøpe inn alt som vil komme fremover av eksterne psu's som kan passe,og lære av designa.
    Det er fryktelig få eksperter på lavveleltronikk psu's der ute nå, vi snakker en 5 -6 virkelige superstjerner i miljøene.
    Kanskje man kan kontakte den man finner er den beste av dem og ha ett samarbeide i fremtiden.
    Alt i alt en innertier av en dac/pre/headamp dette fra Audiolab. (Har ikke hørt den enda... selv) Men fornuften lyser som gladmusikk ut av speclista!
    Her har man en leder i Audiolabs som har grep om dagens marked!!! Det må jeg si!!! Her planlegger man særs fornuftig, ikke minst for kundene sine, litt fremover i tid!
    Denne ser spennende ut! Denne kan jo nermest alt mulig og må jo være ett supert utgangpunkt for ett skikkelig bra moderat dyrt annlegg!
    Naturlig skeptisk audiofil.&nbsp; <br /> http://www.thephora.net/forum/images/smilies/vader.gif <br /><br />All your tweak is belong to me!<br />Imperial by name, tweakMan by nature..
  7. #7
    Hifi-entusiast
    Jul 2008
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Spesifikasjonene tilsier at det er en ES9018 basert sak som bruker 8bit quantizer,
    og som har implementert en variant av mine LSB algoritmer.
    Det blir morsomt å se om de har implementer LSB algoritmene riktig ;D
    Noe jeg nå tviler på etter å ha lest spesifikasjonene en gang til...
    Tåkepraten om "Windows..." gjør meg litt misstenksom ...
  8. #8
    Feb 2002
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Du har sannelig høye tanker om deg selv Oblivion... :P Har du samarbeidet med dem, siden du vet de bruker dine greier?
  9. #9
    Hifi-entusiast
    Jul 2008
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Sitat Sitat fra Imperial
    Du har sannelig høye tanker om deg selv Oblivion...&#160; :P Har du samarbeidet med dem, siden du vet de bruker dine greier?
    Selvfølgelig ;D (tankene og ikke samarbeidet)
    Jeg har da holdt på noen år for å overbevise både HW produsenter og SW produsenter om feilen i standardene.
    Jeg har dokumentert i public domain konseptene langt tilbake i tid...
    De som jeg har sammarbeidet med har implementert dette korrekt.
    Hva andre nå gjør ved å hive seg på "bølgen" vet jeg ikke,
    men det spesifikasjonene for dette produktet sier gjør at jeg tror det er rimelig store muligheter for at implementasjonen ikke er korrekt (i forhold til mine spesifikasjoner)&#160; ;D
    Men det vil være enkelt å sjekke ut når en har produktet fysisk tilstede..
    Ser ikke bort fra at endel SW leverandører / produsenter også vil kommer etter på LSB bølgen.
    Kan nevne noen "brand" som er kjente her på HFS som har fått beskrivelsene:
    J.River, Pure Music, Audiolense, Sox, Weiss...
  10. #10
    Feb 2002
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Ja, for ett produkt å få "not going into oblivion" og No brainer status samtidig, det skal litt til skjønner jeg da.
    Uansett. Du driver med det jeg kaller grunnforskning. Realiseringer på ditt nivå ligger litt frem i tid, jeg tror att produkter idag,funker helt supert med bl.a dine prinsipper i barnestadiet. Såpass tiltro til dine kunnskaper har nemlig jeg. ;D og produsentene som lager greier, du også har peiling på, vi kan jo si det slik...
    Nå driver John Westlake å "tenker" på en bedre mdac psu for tiden, en lettere oppgradering fra den som følger med, originalt.
    skal bli spennende å se hva de kommer opp med,men jeg anntar dette er noe frem i tid.
    Og Ifølge What Hifi låter Mdac så uvanlig bra (bl.a til prisen) allerede att det har skapt litt av en furore, og sikkert ett par kontroverser, som bl.a det vi nå snakker om..
  11. #11
    Hifi-entusiast
    Jul 2008
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Uansett. Du driver med det jeg kaller grunnforskning. Realiseringer på ditt nivå ligger litt frem i tid, jeg tror att produkter idag,funker helt supert med bl.a dine prinsipper i barnestadiet. Såpass tiltro til dine kunnskaper har nemlig jeg.&#160; ;D
    Det er derfor jeg har publisert LSB problematikken (både årsak og løsning, men ikke alle komplikasjonene en må ta i betraktning for å implementere korrekt) tilbake i tid...
    Da er det ingen som kan få patent og alle produsenter kan dra nytte av dette - noe som igjen gjør at alle forbrukere kan få bedre lyd uten å måtte betale noe ekstra.....
  12. #12
    Feb 2002
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Sitat Sitat fra lasse5214
    Trykk på fisken... ;D
    Det er 3 - 4 separate tråder, jeg linker via "fisken" til den første av dem...
    Happy reading! ;D
  13. #13
    Dec 2004
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Sitat Sitat fra Oblivion
    Genialt Egon ;D ;D ;D
    1 # HI-FI : Burson DA160 (DAC). Audionet Sam V2 .&nbsp;T+A TCI 3R <br />Hjemmekino : Yamaha RX-V1067 . Sony BD780&nbsp;. PSB S-50 . SVS12 . EPSON TW700 + Fornuftig valg av kabler (Blue Jeans Cable&#039;s og VDH)<br /><br />2 # Sony PS3 . Onkyo TX-SR508 . System Audio Comet . Panasonic 3D 50&quot;
  14. #14
    Feb 2002
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    http://www.whathifi.com/awards/2011/dacs
    En video, fra What Hifi,om M-dac.
  15. #15
    LMC
    LMC er offline
    Hifi Freak
    Aug 2006
    Drøbak
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    hvorfor skulle denne være noe bedre enn Exadac18 ?
    Leif
    solderslinger og raskere enn sin egen skygge
  16. #16
    Overivrig entusiast aair's Avatar
    Mar 2007
    Ullensaker
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Sitat Sitat fra Todd
    Jupp, hadde den i stua noen timer i jula, men for kort tid i mitt oppsett til å si noe vettugt om den.
    Brodern kjøpte den i UK for flere måneder siden og i hans anlegg låt det meget bra ift parametrene oppløsning og basstrøkk.
    Horn | Vinyl | Oslo Vinylklubb
  17. #17
    Hifi-interessert
    Apr 2007
    Elnesvågen
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Da er M-dac endelig sendt fra UK etter måneder med venting ;D Skal bli spennende dette.
    Stue Hifi: Spendor A6/ Audionet SAM G2/Audionet P10-8 strøm fordeler Synergistic Research Tesla-X4 single wire/ Audiolab M-Dac/ Cambridge NP30 nettverksspiller/BK XLS200 MK2 Sub<br /> Kino rom: Audionet AMP 3/ Emotiva UPA-2x2/ Emotiva UPA-1/ Emotiva Umc-1/ Emotiva Erm-6.3/ Emotiva Erd-1, Monitor Audio GS10/ Abrahamsen høyt kabl
  18. #18
    Hifi-entusiast
    Dec 2008
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Gleder oss til rapport, den ser bare så lekker ut :P
    Vh
    Æsj!<br />Har slettet meg selv fra Sentralen fire ganger, men angrer alltid og må lage en ny &quot;meg&quot; ....skulle vært &quot;angrekomtilbakeuke&quot; ;-)
  19. #19
    Hifi Freak ou812rh's Avatar
    Mar 2006
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Sitat Sitat fra cathrine1
    Vh
    +1
    Densen B-250+, B-330+, Oppo BDP-93, Musical Fidelity V-DAC II/V-PSU II, Musical Innovation MI 14, Michell GyroDec m/Orbe oppgr/HR PSU, SME 309, Benz Ref 3 p.u, Audio Physic Sitara, Audience AU24, Whistler Coanda, Nordost Silver Shadow, Isotek minisub GII, Shunyata/Oyaide strømkabler & kontakter, Ground-it Delux, Vibrapods, Sorte Kone.
  20. #20
    Hifi Freak gismo's Avatar
    Oct 2007
    Kirkenær
    Takk/Liker/Misliker
    Album
    Torget
    Audiolab M-dac
    Sitat Sitat fra Hornet
    Denne ser jeg frem til Hornet
    Iallefall herlig yttre på denne, så får vi høre med om hvordan den oppleves
    gismo
    SB Touch / KingRex PSU MkII / Moon 300D DAC / Audionet PRE1 G2 / Audionet AMP1 / Audio Physic Sitara / REL T-5 + REL T-5
    Whistler Audio / Purist Audio Design
    Musikk spilles ikke fra vinyl eller sølvplater...enjoy the science
Skrive Tillatelser
