Kronos kommer til Endpoint Audio
Endpoint introduserer Kronos i sortimentet! Kronos er et merke jeg har kikket på over en tid og dette er noe jeg har gledet meg til. Dette er platespilleren for deg som ønsker å vri maks ut av analogmediet vinyl! Stabilitet, dynamikk og stillhet er ting vi kan snakke om her.
Kronos kommer med 3 modeller hvor innstegsmodellen Sparta 0,5 kan oppgraderes med et kit til å bli Sparta!
Kronos Pro er toppmodellen og det er også et RIAA trinn og en strømforskyning på vei.
KRONOS
Prisene ligger ute på hvert av produktene.
We are Kronos.
In just a few years, Kronos Audio Products has become a leader in the turntable world.
Kronos has won over 35 awards and “Best of Shows” from the international press along with glowing reviews from the world’s best audio journalists. How can we explain this success?
To put it simply, we aim at building turntables that are truly musical and faithful to the recorded material. To this we add the best performance/price ratio in the marketplace. Finally we strive at building products that are easy to maintain and are built to last.
The first thing that distinguishes a Kronos turntable is its two equal mass platters, rotating opposite each other. We call this the dual platter counter-rotating revolution. It is a means by which the vibration inducing torque force, present in suspended turntables is eliminated. The result of this design is a suspended platform particularly well isolated from environmental and mechanical noise while maintaining unequalled stability. You can immediately hear the difference dynamic stabilization makes. No other turntable can offer its advantages.
Besides this, all of the Kronos turntables components keep other parasitic vibrations to a strict minimum. Our designs apply proven and solid technologies and use materials with complementary properties. Our groundbreaking DC computer controlled drive systems deliver outstanding speed control while remaining vibration free. Our proprietary hyper precision platter bearings rotate smoothly and are maintenance free and durable. Our plinths combine composite materials and metals so as to offer rigidity and minimize acoustical feedback. Our suspension is designed to be highly efficient as well as easy to set up.
Finally, with the help of recording engineers, our turntables have been fine tuned and optimized by comparing their test pressing playback performance to those of original master tapes. This comparative testing process has directed our work in achieving a neutral frequency response, natural timbres and transients and outstanding dynamics.
It is no wonder Kronos turntables are being used in award winning presentations all over the world. Kronos turntables are also chosen by music industry professional and by audio equipment manufacturers. But most importantly, Kronos turntables are providing enjoyment and pride of ownership to members of the audiophile community.
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
