The FLS Series is the newest line from Audia Flight. With the FLS Series we are revisiting elements of our tried and true Classic Series, though the FLS Series takes many of its circuit design cues from our reference Strumento Series. One might say then that the FLS Series represents all we have learned over our 20 plus years with Audia Flight.
The new FLS family has been created to bring the music lover closer to the level of our Strumento Series without the Strumento Series' inherent cost-no-object approach.
Now the first product of this family is available Audia Flight FLS 4
Audia Flight
FLS-4
I must admit that the power amp of the Italian Audia Flight company was added to my list at the very last moment, as I carried out its test for the November issue of “High Fidelity”. It was my first encounter with this company’s product and it rarely happens that I am absolutely amazed by the sound of a transistor after listening to a device for several minutes. It does occur in the case of high-class tubes, but when it comes to quartz-based devices, this does not really ever happen. However, the FSL-4, which costs quite a lot, but still not as much as products of other companies, sounded so good from the start that I could not stop listening to it.Its sound actually has everything that it needs – there is the transistor kick, dynamics, fantastic control of the loudspeakers, speed, drive, incredible energy, but there is also outstanding smoothness, fluidity and some kind of almost tube-like natural sound smoothness. What is surprising is that there is also wonderful space and naturalness of sound, as if it was coming from excellent tube amplifiers.
Veiledende pris på Audia Flight FLS 4 72.990.-
Output power per channel Watts RMS @ 8/4/2 Ohm200/400/900W*
Gain29 dB
Input sensitivity1.41 Volts RMS
Frequency response (1W RMS -3dB)0,3 Hz ÷ 0,7 MHz
Slew-Rate (@ 8 Ohm)> 160 V/µS
THD< 0,05 %
S/N Ratio110 dB
Input impedance Unbalanced7,5 kOhm
Balanced7,5 kOhm
Damping factor (@ 8 Ohm)> 650
Main voltage AC (50-60Hz)100, 110-115, 220-230, 240 V
Stand-by Power consumptionless than 1W
Nominal Power consumption (no signal)170W
Power consumption (200W RMS @ 8 Ohm both channels)840W
Dimensions and weight450x1770x440mm (W x H x D) - 34kg
Shipping dimensions and weight575x280x545mm (W x H x D) - 42kg
Det vil etter vært også komme nå i starten av 2017 en pre amp FLS 1, integrated amp FLS 5, FLS 3 cd player, FLS 2 dac 32bit 348khz og FLS 6 cd transport.
Liten sniktitt av FLS 5 som vil bli lansert i løpet av februar.
JWK Audio/Sound of heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
