Den mest avanserte dacen fra April Music til dags dato er nå lansert etter 2 års utvikling. Setter en ny standard for lydkvalitet i sin prisklasse.
44,1 til 384 khz kompatibel via usb, og 64 og 128 kompatibel DSD. Lar deg også upsample 44.1 til DSD.
Pris kr. 13600,- På lager nå.
post@andervikaudio.no
Tlf: 92012111
Andervik Audio
DIGITAL INPUTS | FPGA Based Audio Processor 1 x AES/EBU 1 x COAX 2 x OPT 1 x USB 2.0 |
PC USB Link | High Speed USB Audio Interface with FPGA Based Audio Processor Mac OSX 10.6+ Linux with UAC2 Compliant kernel Windows OS |
SAMPLING FREQUENCY | AES/EBU, COAX, OPT - up to 192kHz USB - PCM 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz USB - DSD64, DSD128 |
UPSAMPLING | Bidirectional Estimator Up to 384kHz |
ANALOG OUTPUTS | 1 x RCA 1 x XLR |
OUTPUT SIGNAL LEVEL | Unbalanced 2.6Vrms Balanced 2.6Vrms on each leg |
OUTPUT IMPEDANCE | 50 Ohms |
DAC | ES9018K2M Sabre32 Reference Audio DAC Dynamic Range 127db THD+N -120db |
FRONT DISPLAY | 14 Segment Alphanumeric LED |
FRONT PANEL | Power on/off Push Button Switch Power LED Input Selection Button : USB, COAX, OPT1, OPT2, AES/EBU Menu Button Enter Button |
AC POWER REQUIREMENT | 100/117/220(230)/240V, 50 or 60 Hz |
DIMENSION | 219 x 54 x 296 (WHD) mm |
WEIGHT | 3Kg(net) |
343 KB Visninger: 1.245
413.3 KB Visninger: 1.222
379 KB Visninger: 1.254
313.9 KB Visninger: 1.277
