Fatsound.no
- Ble medlem
- 26.10.2010
- Innlegg
- 10
- Antall liker
- 0
Abrahamsen FS401 2½-veis høyttalere
Interessert? send en mail til admin@fatsound.no, ring Tlf: 93055686 (Man-Fre 17:00 - 21:30 & Lør 12:00-22:00) eller besøk vår nettside www.fatsound.no
Alle produkter produkter - 10% ut desember (Abrahamsen, Neotech, Furutech, Fatsound.no FAT...)
This is the first in a new range of loudspeakers designed to be compatible with the V series of amplifiers and other high quality audio equipment. The FS401 uses 5 drive units from the highly respected manufacturer SEAS. The units are used in a 2½ way bass reflex design.
4 x Bass mid-range units 1 x Tweeter
Bass reflex design Listening area up to ±30°
Seas SpiderRing® technology Extruded aluminium profile
Direct Signal Connector (DSC) High gloss grand piano finish
Width(cm) 20.5 (24 w/base) Height(cm) 110
Depth(cm) 29 (35 w/base) Weight(kg) 25
In room frequency range: 35Hz 35kHz
Impedance nominal: 6 ohm
Sensitivity: 92dB/W
Jan Erik Helland
Fatsound.no
Sensitivity: 92dB/W
Jan Erik Helland
Fatsound.no
