Velkommen, Gjest. Vennligst logg inn eller registrer deg.
Logg inn med brukernavn, passord og innloggingstid
Annonsører:
Sider: 1 ... 12 13 14 [15] 16 17 18 ... 127   Til bunnen
  Skriv ut
Skrevet av Emne: Egen tråd for Hodetelefonoppsett?  (Lest 77126 ganger)
0 Medlemmer og 1 gjest leser dette emnet.
SOEDAL
Hifi Freak
Utlogget Utlogget
WWW
« Svar #280 Lagt ut: februar 23, 2010, 23:33:03 »
Har en sak på vei til mine DT770pro
Matrix Mini-i Balanced DAC/Pre
Specs:
* D/A DAC chip AD1955 x 2
* Full balanced stereo design
* Up to 24Bit/192kHz sampling
* Low jitter receiver chips and seperate clock
* Built-in headphone amplifier, for up to 600 ohm headphones
* OP275/OPA2604 opamps
* Balanced/Unbalanced outputs
* Various inputs
* Large screen VFD
* Designed and tuned for audiophile
* Digital Input:
- Optical: toslink, 44.1-192kHz
- Coaxial: 75 ohm RCA/BNC, 44.1-192kHz
- USB: USB-B, 44.1-48kHz
- AES/EBU: Standard XLR balanced, 44.1-192kHz
* Digital Output:
- Coaxial RCA
- 44.1-192kHz
- Support AC3, DTS
* Analog Interface:
- RCA/XLR
- Frequency Response: 20-20kHz
- Signal to Noise Ratio: 120dB
- Dynamic Range: 118dB
- Distortion 0.0002% (1kHz)
- Stereo Separation: 110dB
* Power Support: AC 220-240V/100-120V (Please specify)
* Front Panel Color: Silver
* Case Color: Black/Silver (Please specify)
* Weight: 2 kg
* Dimension: 205 x 155 x 48mm (L x W x H)
Mer info om den på head-fi
http://www.head-fi.org/forums/f5/matrix-mini-i-balanced-dac-hp-amp-441960/
DEN VAR RÅ!
Loggført
Min tråd. Oppdatert 15.08.11 http://www.hifisentralen.no/forum/index.php/topic,10968.msg1188286.html#msg1188286
Michell Gyro SE/Michell Tecnoarm/AT oc9ml2
Apple Imac/Arcam rDac/TeddyrDacPS
Quad Elite Preamp/monoblokker
JBL LS80 / JBL ES250PW
T A F
Utlogget Utlogget
Class A og Vinyl rocker.
« Svar #281 Lagt ut: februar 24, 2010, 07:03:17 »
Specs:
* Various inputs
* Large screen VFD
* Digital Input:
* Digital Output:
- Coaxial RCA
- 44.1-192kHz
- Support AC3, DTS
* Analog Interface:
- RCA/XLR
* Weight: 2 kg
Hvor kjøpte du denne? Har du link?
TAF
Loggført
Tannoy Prestige Kensington SE * Accuphase E-550 *
Squeezebox Touch * Accuphase DAC20 *
Thorens TD124 /SME 309/AT33EV *Accuphase AD20 *
Denon AH-D5000 * AudioTechnica ATH-M50 *
Analysis Plus kabler*
mteinum
Hifi Freak
Utlogget Utlogget
rør i sør
WWW
« Svar #282 Lagt ut: februar 24, 2010, 07:25:01 »
Ser ut som det er mange som kjøper denne på ebay.
eks: http://stores.shop.ebay.com.sg/TAMS-AUDIO
omtale: http://www.affordableaudio.org/aa2009-12.pdf
Loggført
Monopulse 42A, Kingrex T20/SLAP!/PSU, Burson HA-160D/PP-160/PRE-160/HA-160/DAC-160, MAE SET, Bottlehead Foreplay, AKG K-702, Squeezebox Classic / Touch, Trafomatic Audio Aries, Dallas II (Fostex FE203En-S)
ottone
Hifi Freak
Utlogget Utlogget
« Svar #283 Lagt ut: februar 24, 2010, 07:34:34 »
Interessant.
Available through ebay only.
Loggført
Arcam rDac/Sugden CD21/Headmaster/Sugden A21AP/Harbeth SHL5/Sennheiser HD800
MacbookPro/Nuforce Icon HDP/AKG 701
LinnLP12/DV17/GrahamSleeReflex/AN dac3/AI L2/QuadII/ESL63/Stax Lambda på lager
Ulf-B
Hifi Freak
Utlogget Utlogget
« Svar #284 Lagt ut: februar 24, 2010, 16:14:23 »
Et års tid siden forrige gang jeg skrev i denne tråden.  I dag ble mine gamle Denon AH-D750 fra 1996 erstattet med et par flunkende nye Denon AH-D2000.  Det låter et par strå hvassere - ingen tvil om det.  Selv uten innspilling.  Benchmark DAC-1 driver også disse nye Denon'ene på en aldeles utmerket måte - overraskende bra hodetelefonforsterker i Benchmark'en.  I hvert fall bra nok til at jeg ikke har planer om noe mer.  Holder lenge til kveldsbruk foran PCen når kona har gått og lagt seg.  Bedre lyttekomfort, også, på de nye hodetelefonene - de klemmer ikke på ørene i det hele tatt, slik de gamle hodetelefonene gjorde.  Verden går tydeligvis fremover.
Loggført
1) Squeezebox Duet m/iPad, Beolab 5
2) Squeezebox Classic, Weiss DAC-1 MkII, Get-boks, Copland DRC-205, Primare DVD30, Mark Levinson 320s, Bryston PowerPac 300 SST, ProAc Response D1, Amphion Impact 500 sub
3) Squeezebox Duet, Benchmark DAC-1 Pre, Jeff Rowland 102, Epos M-5, ProAc Response ER-1 sub
gwikse
Hifi-entusiast
Utlogget Utlogget
DOH
« Svar #285 Lagt ut: februar 25, 2010, 18:38:46 »
Tror du har endel å glede deg til når de er innkjørt også.
Nå har Matrix`n kommet til Gardemoen  Gliser . Venter "bare" på tollen nå....
Loggført
MediaCenter 17 | .... DIY ..... | Nordost Heimdall | AP Virgo V
Min HiFi|Min DIY
gwh
Hifi-interessert
Utlogget Utlogget
« Svar #286 Lagt ut: april 17, 2010, 11:05:20 »
Da har jeg hatt en Burson HA 160 et par dager på lån fra Moiz, og det er klart løft i separasjon og klarhet ifra min Little Dot 1+, det er det ingen tvil om.
Det er en kraftig og god klump den hodetelefonforsterkeren:)
kjøres sammen med en gamma2 dac, en musiland 02 usb->spdif 24/192 konverter og en minipc.
En god grunn til å gå på jobb hver dag.
Loggført
mteinum
Hifi Freak
Utlogget Utlogget
rør i sør
WWW
« Svar #287 Lagt ut: april 17, 2010, 11:10:17 »
Og hva er det du har på hodet?  Gliser
Loggført
gwh
Hifi-interessert
Utlogget Utlogget
« Svar #288 Lagt ut: april 17, 2010, 12:27:10 »
Noen billige denon d7000, takke gud ofr kollegaer som var hjemme i unitain i juleferien Gliser
Loggført
eldo472
Hifi-entusiast
Utlogget Utlogget
« Svar #289 Lagt ut: april 17, 2010, 14:17:47 »
Hvilke forsterkere/CD-Spillere har gode hode hodetelefon utganger ?
Jeg har et par Sony MDR-F1 hodetelefoner som jeg har prøvd på en rekke komponenter.
Den beste forsterkeren jeg har hatt var en Sansui Alpha 907DR.
Hadde en Sony XA707ES koblet med Supra balanserte kabler på Amp direct inngangen på 907DR. Etter litt prøving syntes jeg høretelefon utgangen på XA707ES var bedre. Muligens skyldes dette enda korter signal vei.
Har også en DTC-77ES DAT med bra hodetelefon utgang, men 707ES var bedre fordi den hadde bedre DAC. Nå har jeg uheldigvis solgt både 907DR og XA707ES, men jeg har fremdelens DTC-77ES og den er bedre enn de senere surround forsterkere jeg har hatt.
I tillegg har jeg kjøpt en Sony DTC-2000ES. Den har samme DAC og digital filter som XA707ES og har også veldig bra lyd på høretelefonene slik at jeg har brukt den endel på hodetelefon lytting i det siste.
Sony CDP-XA707ES, DTC-77ES og DTC-2000ES har veldig bra trøkk på hodetelefon utgangen. Disse er jo eldre kvalitets modeller hvor det er tatt få snarveier og de har tydeligvis også laget god lyd på hodetelefon utgangene også.
Kan derfor anbefale andre og prøve en eldre ES cd spiller.
Loggført
Sony entusiast
trex
Utlogget Utlogget
« Svar #290 Lagt ut: april 18, 2010, 15:37:16 »
Kommet noen nye Shure, http://www.belco.no/nor/headset_in_ear/headset_oerepropper/shure_srh840
som skal være meget bra til prisen for de som måtte være interessert.
Loggført
Smibakkjen
Hifi-entusiast
Utlogget Utlogget
« Svar #291 Lagt ut: april 23, 2010, 16:04:10 »
Har nå endelig fått hentelappen på noen Grado SR325is, som kommer noe forsinket fra USA, gleder meg Gliser
Loggført
Papworth Audio Technology MIA 200, Klipsch KLF 20/RB 81, Event Opal, Logitech Squeezebox Duet,  Benchmark DAC1 HDR og Beyerdynamic DT 770 Pro 80Ω/
DT 880 250Ω/DT 990 250Ω/Grado SR325is
hifinisse
Hifi-entusiast
Utlogget Utlogget
« Svar #292 Lagt ut: juni 05, 2010, 00:24:22 »
Litt Head Fi i dag, spiller på Trafomatic Experience Head One..
Veldig gøy!!!
Loggført
"Spend more on your development than you do at the coffe shop" - Randy Gage
emotikon
Hifi Freak
Utlogget Utlogget
Er det rart det bikker over av og til....?
« Svar #293 Lagt ut: juni 05, 2010, 00:53:52 »
Veldig gøy!!!
Sammen med?
Loggført
emotikon
"Without music, life would be an error."
- Nietzsche
 ‎"Too many pieces of music finish too long after the end."
- Igor Stravinsky
Supertramp
« Svar #294 Lagt ut: juli 28, 2010, 20:38:48 »
Etter tips fra en hyggelig fyr på AVF, ble det handlet på ebay og i dag kom denne pakken:
Pakken med mva-registrering - ikke ublu avgift, kr 217,-
Out of the box
Og her er innholdet.
Det første jeg la merke til er den profesjonelle løsningen med spiral-metall der kabel føres inn i jackpluggen. Slikt ser man også på profesjonelt utstyr.
Og den hendige bag'en som man pakker ned headsetet når man er på reise.
Solid jack
Og også en bra mini-jack gjenget på jack'en
Lyden:
her er ikke annet å si enn at dette er bang-for-bucks så det holder.
Skålene isolerer veldig godt, noe som var veldig viktig i valg av merke/type. Lekkasje ut/inn er nærmest fraværende.
Og ATH-M50 gir et nydelig lydbilde.
Frekvensrespons:
De går dypt. Dypbass (om man kan kalle det slikt på klokker) legger man godt merke til på Avratz (Infected Mushroom), Planet Dada Flamboyant (Yello) og Also sprach Zarathustra (OST fra 2001: A Space Odyssey).
Bass forøvrig er flott; passe tight. Mellomtonen er behagelig tilstede og diskantområde er ikke masete.
"The M50's excellent clarity, rich musical detail, and clean extension both high & low will surprise when comparing to others in the category at similar price points.", nettopp - det er slik de er.
Komfort: de er tette! Med kunststoff (skai?) blir det noe klamt, men ikke verre enn at det kun er merkbart etter lengre lyddetid.
Byggekvalitet:
denne er solid. Det er kvalitet hele veien; fra klokker, via kabel til jack. Kabelen er coiled på disse, men de finnes også som straight. Coiled er en fordel om man skal bruke klokkene til en mobil enhet.
Holografien og kanalseparasjonen er fantastisk. Testlåt Private Investigations med Dire Straits. Denne detaljerte låta presenteres på en fenomenal måte. Man får følelsen av å være i studio med Dire Straits. En klarhet og åpenhet jeg ikke har hørt i klokker før. Dynamikken er påfallende uten at de sterke partiene blir ubehagelig å høre på.
Testmateriale ble spilt på PC>  FLAC filer > USB > Beresford DAC TC-7520
(fruen hadde TV på like ved siden av lytteplassen uten at det ene eller det andre var sjenerende for noen av oss)
Loggført
Todd
Hifi Freak
Utlogget Utlogget
« Svar #295 Lagt ut: juli 28, 2010, 21:03:21 »
Grattis med nye hodetlf. Supertramp! Har et par ATH-M50 jeg også som jeg benytter som alternativ til mine Grado klokker. Sammen med min Beresford TC-7520 DAC/AMP låter det meget godt. Value for money, o yeah!
Loggført
Squeezebox Touch > Beresford TC-7520 > Naim Nait 5i > Kudos X2
Supertramp
« Svar #296 Lagt ut: juli 28, 2010, 21:09:18 »
Pussig at vi er i samme "båt" : Beresford/Grado (jeg har SR60 fra før) /ATH-M50 Glad
Sånn er det når kvalitetsbevisste velger rett - hehe
Loggført
Todd
Hifi Freak
Utlogget Utlogget
« Svar #297 Lagt ut: juli 28, 2010, 21:31:47 »
Jepp  Gliser Synes spesielt Beresford/Grado gir mye synergi. Låter knallbra sammen. Ikke så verst den headphone ampen i Beresforden egentlig.
Loggført
Julenissen
Hifi-entusiast
Utlogget Utlogget
« Svar #298 Lagt ut: juli 28, 2010, 22:48:19 »
Noen som vet om det er mulig å bygge om driverene til Stax fra 110 til 230V?Tips om hvor man får Stax billig ute i verden?(jeg slipper moms/toll)
Loggført
ErosLoveking
Hifi Freak
Utlogget Utlogget
Life is too short for boring hifi-muzak!
WWW
« Svar #299 Lagt ut: juli 28, 2010, 23:08:04 »
Noen som har erfaringer med Trafomatic Experience Head One? evt. hvilke rør?
Loggført
Manley Shrimp+Snapper, Impulse H6, Ear324, VPI Ssm, Benz LP, Lyra Skala+Helikon mono, AT33ev, KimberSilverstr, Furutech, Sony dvd,Grace M903, VPI 17.5, Sennh.HD650+AKG K701m+Beyerd.T1, Cayin HA-1A, iMac, Wurlitzer 2410.  "Den beste, med de beste" ?? Gnagsår langt under streken. Patetiske skinnhellige, up yours. sic!
Sider: 1 ... 12 13 14 [15] 16 17 18 ... 127   Til toppen
  Skriv ut
Gå til:
Linker til omtaler
Søk i Wikipedia
