Forside
Forum
Bruktbørs
Linker
Galleri
Toppen
Hoyre
Velkommen,
. Vennligst
logg inn
eller
registrer deg
1 time
1 dag
1 uke
1 måned
Alltid
Logg inn med brukernavn, passord og innloggingstid
BruktbØrs
Logg inn
Registrer
Bruktbørs
Forhandlere
Salg av nye produkter
Merlin VSM.
Annonsører:
Skriv ut
Lagt ut av
Annonse: Merlin VSM. (Lest 481 ganger)
StudioSound
Hifi-interessert
annonser: 55
Jeg digger dette forum!
Merlin VSM.
den:
januar 05, 2012, 06:36:28 »
Før 32.495 kr./stk.
Nu 19.995 kr./stk.
Enclosure: Vented (front) and tuned to 37 Hz Super strong glued Pan Fiber construction 1 1/2" thick front baffle Mass loaded Internal and external resonance damping Floor standing with dynamic coupling feet Low diffraction High durability three step textured black finish standard on VSM-MM Premium high-gloss color finishes standard on VSM-MX Brass tuning rods on front and top of cabinet Hand-crafted speaker grills included Woofer: 6.5 inch paper carbon-fiber cone Cast aluminum basket Low diffraction rubber surround Large motor, rear vented Specifically manufactured for Merlin Music Systems by ScanSpeak Tweeter: 1 inch soft dome Dynaudio Esotar D330/A Crossover: Highly optimized 12 dB per octave Crossover point at 2200 Hz Both drivers wired in electrical phase Fixed output (no level controls) Impedance corrected Electronic circuit damping Proprietary ultra-low loss inductors by Hovland Hovland Aluminum foil and polypropylene capacitors Caddock Micronox® Film resistors Wired with Cardas wire Bi-wireable via Cardas "low stress" binding posts Removable outboard RC Networks EMI/RFI filtering networks Point-to-point hand wired Easily removable for upgrades/repairs Bass Augmentation Module (BAM): 5.2dB of boost at 35 Hz Subsonic bass roll-off below 27Hz Outboard power supply Optional rechargeable battery power supply Single ended (RCA) or fully balanced (XLR) models available Cardas Cross internal wiring Caddock Micronox® Film resistors Hovland Aluminum foil and polypropylene capacitors Input impedance: 40k ohms Output impedance: 100 ohms THD: < 0.005% Maximum output voltage: 9.5Vrms Power requirements: 50/60Hz 110VAC to 117VAC.
Frequency Response: 33-22 kHz +/- 2dB, 1 meter on axis
4dB down at 30Hz with BAM in circuit
36-20kHz +/- 1.75 dB, 1 meter on axis
36-20kHz +/- 1.5 dB at 10° off axis (optimum listening axis)
Acoustic phase shift: Less than 10°
Impedance: 8 ohms nominal 6.5 ohms minimum 15.6 ohms at crossover point
Sensitivity: 89 dB, 1W/1M (2.83V)
Excellent tube amplifier compatibility
Power Handling: 200 watts (program)
Maximum output 111 dB (program)
Power requirements suggested: 17 watts minimum (tube) 25 watts minimum (solid state) 200 watts maximum
Dimensions and Weight: Speakers: 8-5/8 inches wide by 10-1/2 inches deep by 42-7/8 inches high 84.5 lbs. each
BAM: 6-3/4 inches wide by 8-3/4 inches deep by 2-1/4 inches high
195 lbs. in packaging (one pair in carton with BAM)
Warranty: 10 years parts and labor Options:
Fully balanced (XLR input/output) Battery BAM. Includes a self contained, rechargeable battery power supply. Single ended/Balanced BAM unit with self contained rechargeable power supply available.
(18.46 KB, 150x305 - vist 399 ganger.)
(47.64 KB, 330x730 - vist 399 ganger.)
Loggført
Mvh, Karsten og Bjarke.
studiosound.dk
Skriv ut
« forrige
neste »
Gå til:
Vennligst velg en destinasjon:
Selges
=> Forsterkere
=> CD/DVD/SACD-spillere, DAC'er, Drivverk, Radio og dig. equalizere
=> Høyttalere
=> Kabler, strømfiltre og tweaks
=> Hifimøbler, vibrasjon og romtuning
=> Hodetelefoner og utstyr
=> Løse rør
=> Løse komponenter
=> Platespillere m/tilbehør
=> Vintage utstyr
=> Musikk / Filmer / Spill
=> Bilde
=> Bilstereo
=> Diverse
Kjøpes
=> Kjøpes
Forhandlere
=> Salg av nye produkter
Annonseoversikt
Trykk her for nyeste 100 annonser
Nyeste 20 fra bruktbørsen
FLYTTET: Tara Labs Refere...
FLYTTET: Technics SA-527...
Hegel HD-10 DAC ## SOLGT#...
Hegel CDP-2A ##SOLGT##
Blu Ray filmer selges
Integrert med RIAA og DAC
Strøken Rotel RB-1090 og ...
NAD 118 digital forforste...
Myryad MA360 effektforste...
Store vintage høyttalere ...
Chord Cobra plus XLR selg...
JBL LS 80 Ebony
Supra strømfordeler og xi...
Cyrus Bi-wire høyttalerka...
Naim HiCap Olive - 2500,-
Nordost Heimdall signalka...
Aesthetix Calypso forfors...
Audiovector Mi3 Signature
Rørtester selges
Tanberg Huldra 10
Nyeste fra Høium Hifi
Gamut CD3 cd-spiller
Tannoy Kingdom Royal
Solid Tech Rack of Silence
Plinius SA-103 effektfors...
EAR 868 rørforforsterker...
Focal Chorus 806V stativh...
Ny pris! Focal Electra 10...
Wadia 381 cd-spiller KUPP!!
Verity Audio Sarastro II ...
Linn Akurate 4200 effektf...
Andre bruktbørser
Norske
AVforum
Lyd & Bilde
Finn.no
QXL.no
Utenlandske
Hifimagasinet
Audiogon
Legg ut annonse
